68 coupe rear interior clip question - NCRS Discussion Boards
  • Russ S.
    • April 6, 2010
    • 134
    The two rear roof trim parts on the coupe are held in place by a pin that slides into a clip in the top. The clip is riveted in place and has two spring steel fingers that grab the pin. The fingers on my clips are bent up and will not grab the pin. I tried to pull the fingers down with a home made rod but they will not bend back.
    Any solutions short of changing the clips (looks too risky).
