Replacement air filter for 365hp - NCRS Discussion Boards
  • Jim R.
    • June 30, 2001
    • 643
    Just wondering if anyone knows of a replacement paper air filter element that would work on the 365hp without the top of the air cleaner hitting the hood when the engine moves around, last I looked the closest was about a 1/4" higher than the foam/screen original.
    JR
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Replacement air filter for 365hp
    The AC Spark Plug A353C should be a direct drop-in; same height as the screen.
    • Jim R.
      • June 30, 2001
      • 643
      AC spark plug?
      JR
      • Wayne M.
        • March 1, 1980
        • 6414
        Jim, more info -- there's two on eBay right now. They're made by AC Spark Plug Division of GM, but the emboss is AC Spark Plug (see pic below, of one @ $50 used. buy-it-now), link:
        Another NOS @ $300. link:
        x
        • Jim R.
          • June 30, 2001
          • 643
          Wayne do you know the height of the 353 and does the air cleaner end up with a gap between the cover and the bottom piece.
          JR
          • Wayne M.
            • March 1, 1980
            • 6414
            Caliper measure: my original screen (w/o foam element) 1.885" height. My service A353C, 2.05 to 1.80" high [edge is not flat, and designed to contact a slight bevel in the lid]. No gap, proof is when I remove the lid, the element sticks to the lid, so obvious contact.
            • Jim R.
              • June 30, 2001
              • 643
              Wayne thanks for the measurements. Jim
              JR
