While installing my new shifter on my rebuilt Muncie I noticed that the shift levers are somewhat sloppy on the shaft. After tightening them up with the nut and washers they seem fine. but I am now wondering if I shouldn't shim them up a bit . In other words make the shift levers so firm that the nut is only there to hold them on , not firm them up as well ?
That is my first reaction as it seems correct , but want to make sure a little slop or give isn't built into the system for a reason .
For you really tech minded guys : "SLOP" means I can insert , albeit with much force , a .015 feeler gauge tip into the slot of the shift lever after it is all the way on the shaft .Having never worked on a muncie before , I have no idea if this is good , fair or excessive
Jim
Jim
