Restore a C1 Eaton gas cap - NCRS Discussion Boards
  • Ian G.
    • September 3, 2007
    • 1114
    Does anyone know a restorer who rebuilds C1 gas caps? Specifically a 1958-62 Eaton gas cap? I could replate it fine, but not sure how I'd replace the paper gasket... and the gasket will not survive replating I imagine. I could maybe glue a paper gasket in there? riveting would be tough, as the head of the rivet is square. The company that reproduces the 57-58 eaton gas cap says they could give it a try, but for $125 - but he's not sure he could do it, and wants me to replate it myself -- which means I need to remove the rivet, ruining the cap potentially.
    I could buy an NOS cap for $170 on ebay, so I'm hesitant to spend that kind of money for an unproven vendor.
  • Joel M.
    • May 31, 1975
    • 141
    Re: Restore a C1 Eaton gas cap
    Talk to John Pirkle Jr -------706-855-1177 ------ work is 1st class.
    • Ian G.
      • September 3, 2007
      • 1114
      Thanks. I didn't realize he did stuff aside from electrical components. I have a regulator and generator by their shop already
      • John F.
        • March 23, 2008
        • 2395
        Ian, Over on the other forum, Top Flight Reproductions has the Fuller Emerson & Stant caps for $150 for 58-62 vettes. Cll Ray at (781)279-1279.
        • Ian G.
          • September 3, 2007
          • 1114
          I actually corresponded with them and he offered to restore my gas cap for $100-125, but wasn't sure if he could do it. So I'm shopping around for people with a track record...
          • Jerry C.
            • November 1, 1995
            • 741
            Joe Perri 312 307 1977 or 773 631 1449
            • Ian G.
              • September 3, 2007
              • 1114
              I've been in touch with Joe Perri. Very informative guy!
              • Michael H.
                • December 1, 2004
                • 118
                So is there a way for a do-it-yourselfer to restore the early C-1 gas caps? Specifically, pursuant to the original question, is there a way to replace the gasket? I was wondering it if would be possible to cut out the old gasket, clean and replate the cap, and then fold and bend a new gasket in such a manner as to "stretch" it over the inner ears of the gas cap?
                • Jerry B.
                  • August 31, 1994
                  • 416
                  I was told that if you soak the paper gasket in water , it will slip over the tangs. Be patient it works.
                  • John P.
                    • August 31, 1991
                    • 94
                    Jerry is right. Two things to remember; use the correct gasket material and work slowly(be patient).
                    • David S.
                      • August 9, 2009
                      • 595
                      Absolutely send it to Joe. He is hands down the best there is.
                      Best,
                      Dave
