Exhaust Manifold Paint - NCRS Discussion Boards
  • Dale M.
    • December 27, 2007
    • 386
    Re: Exhaust Manifold Paint
    Dan, Thanks for the information, great suggestion. I have a good friend here with a mostly original that I use to verify my car. I will check that out. This would be an easy fix. I am having issues with my overflow tank, it has some pin hole leaks. Mostly on the bottom nipple. Someone has welded the nipples, but it seems to be the original for my car. I used some JB Weld and it seems to be holding pressure. I am also looking at raditors, mine has been replaced and it has a small leak. I am checking out the Dewitt's. Again, Thanks.
    • Gene M.
      • April 1, 1985
      • 4232
      Dale,
      If you drive your car I would not rely on epoxy to keep the tank from leaking. New tanks are available with all the same stampings as your original.
      • Dale M.
        • December 27, 2007
        • 386
        Originally posted by Gene Manno (8571)
        Dale,
        I am just hoping to get by until I can get a new tank. I agree with you, Thanks for getting back with your thoughts. Dale
