71 Corvette Wheels and Tires - NCRS Discussion Boards
  • Seth G.
    • March 1, 1987
    • 116
    I need help replacing my original 15x8 AZ coded Rally Wheels and F70-15 Goodyear speedways that I want to preserve and only use for show. Will an OEM set of 15x8 Rally Steel Wheels with a 4" backspace fit properly using a size 215/70-15 radial tire? If so, can anyone recommend a good source to purchase them from? Lots of confusion out there! Thank you, Seth
  • Chris H.
    • April 1, 2000
    • 837
    Re: 71 Corvette Wheels and Tires
    Seth, used AZs are pretty easy to find. They started in '69 and went through '72. If you want "new" I believe any of the big houses (Ecklers, etc.) sells them.
    • Mike E.
      • February 28, 1975
      • 5134
      They actually went through 82. You're right-they're not hard to find.
      • Rey S.
        • April 1, 1995
        • 277
        Hi Seth
        Flea/swap meets are a great source for wheels. Be carefull with aftermarket wheels, some do not have proper centers around the bolt areas. As these wheels flex over a period of time the lugs will loosen up. Also Monte Carlos used a wheel that looks the same but there is an 1/4" difference in the Offset (back spacing ?) so that the Corvette beauty rings WILL not fit the MC wheels. MC wheels and their proper rings will work.
        Good luck !
        Rey Stenhouse 26007
        72 LS-502 Coupe
