I have a coil 1115207 D514 Brass terminals studs, there a no numbers embossed on it. is there any value to it. it is in a Delco box
Transistor Ignition coil
- Top
Re: Transistor Ignition coil
Is this one of those later GM service units with the part # stencilled in white on it ? I remember ordering a '207' at the local GM dealer in the early '80s, and when I opened the box, immediately returned it. I can't recall if it had the Delco sticker, and if it did, whether it was the original '60s style with foil on a paper adhesive backing.- Top
