Recently my turn signals stopped flashing in my 63 SWC. All the bulbs are good and turn on when the signal lever is activated but no flash. I spent a lot of money for a $2.95 signal Stat 143 flasher, the same exact one that the car came with originally, but that did not correct the problem. Is there a common ground for this system? The battery is fully charged as I know a weak battery can slow down or stop the flasher from working.
Signal lamps won't flash. Why?
Re: Signal lamps won't flash. Why?
Perry,
if the light that are supposed to come on, come on, but the only issue is that they do not flash, you were headed in the right direction.
Try another flasher. All a flasher does is interrupt a circuit that is working correctly.
It should not matter, but make sure the emergency flasher button is not pushes in. In fact, try your emergency flashers to make sure they all come on the way they are supposed to.
Try the flasher itself. Put power to one terminal and ground the other. It should click.- Top
Perry, if you have the 1157 bulbs installed in your car the 143 flasher will not flash correctly, try getting a 552 flasher from the pars store. 63 cars used a 1034 bulbNew England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
I did not know my 63 had an emergency flasher. How do I activate the emergency flasher.
As Monte stated it could be the flasher. There are 2 bulb and 3 bulb flashers for a 63.
'63 w/o back up lamps: Tung-Sol AP373V or Signal-Stat 143
'63 with back up lamp: " 322 " 142
Perry. Try and find some good USA bulbs/lamps also.- Top
Perry - Do the brake lights work?
Also, someone has suggested getting a new 552 flasher and installing it and seeing if the flashers work. The 552 is a variable load flasher so if it works, it sounds like the NOS Signal-Stat flasher might be a problem. BTW, what is the Signal-Stat flasher model number? Pete- Top
Yes, the brake lights work. The flasher is a 143 model. When the signal is turned on, and it doesn't matter which way, left or right, the outer bulb gets bright and the inner bulb is dim but no flash. The front lights get bright as well and no flash. I'm confused. I will get the 552 flasher and see if that works. What would the chances of two failed 143 flashers?- Top
To do that do you simply connect one of the terminals to a positive post of a battery and the other terminal to the negative post? Does it matter which terminal to + or -? Then I assume you listen or feel for a click?- Top
Perry,
From reading your post #8 it sounds like there is a ground issue and if it's the same L/R with the dim bulb, process of elimination is the way to find the problem. The rear harness grounds through the main harness to the birdcage but double check the wiring diagram.
I know you stated the bulbs are good but double check to make sure there are not two burnt out 1034's there.- Top
Perry -Yes, the brake lights work. The flasher is a 143 model. When the signal is turned on, and it doesn't matter which way, left or right, the outer bulb gets bright and the inner bulb is dim but no flash. The front lights get bright as well and no flash. I'm confused. I will get the 552 flasher and see if that works. What would the chances of two failed 143 flashers?
I'd remove the lenses and bulbs from the inboard rear lamps and look for corroded sockets/connectors; with a voltmeter, you should show the same voltage on both socket contacts - something is causing a voltage drop or resistance that makes them "dim".- Top
Perry,Yes, the brake lights work. The flasher is a 143 model. When the signal is turned on, and it doesn't matter which way, left or right, the outer bulb gets bright and the inner bulb is dim but no flash. The front lights get bright as well and no flash. I'm confused. I will get the 552 flasher and see if that works. What would the chances of two failed 143 flashers?
It sounds like you have a poor ground at the rear inboard lamps. You can use a small jumper wire and touch it to the chrome part of the lamp housing and the bumper just for a test.- Top
