"Burping" the cooling system on a C1 - NCRS Discussion Boards
  • Garry E.
    • September 30, 2002
    • 240
    Does anyone have any recommendations on effectively "burping" the cooling system on a C1.....? I drained the radiator and now have air in the cooling system...... any good ideas on removing the air.... Thanks ....... Garry Eastwood # 38705
  • Bob R.
    • June 30, 2002
    • 1595
    Re: "Burping" the cooling system on a C1
    I am a C2 not C1 guy but try running the car with the cap removed. Then add water as the level drops.
    • Donald H.
      • November 2, 2009
      • 2580
      I recently filled my 1960 system after reinstalling the engine and new radiator. I just filled through the radiator cap and kept refilling over a few days before first start of freshly rebuilt engine. Then added water as necessary at engine run in.
      I also drained and flushed my 1966. Including removing the drain plugs in the block. Filled through the overflow tanks, ran and refilled as necessary.
      I not much of a mechanic, but what happens to make you sure you have trapped air in the cooling system?
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
        Garry -
        I fill my C1's and C2's the same way, have never had an "air" problem. I fill the system first through the thermostat opening in the intake manifold until the coolant rises to the top, install the thermostat and bolt down the housing, and finish filling through the radiator fill (C1) or through the expansion tank (C2), start it and let it run without the cap until the thermostat opens, then finish the fill to the proper level (tank half-full COLD on a C2).
        • Christopher R.
          • March 31, 1975
          • 1599
          On my '62, the upper radiator hose is higher than the expansion tank. So, with the expansion tank 1/2 full at cold, the upper radiator hose is empty of coolant. So, there's always air in the cooling system. Does it expel the air and suck in the coolant when the engine is running and the thermostat open?
          • Bob R.
            • June 30, 2002
            • 1595
            The system sucks water in from the bottom of the radiator to the engine and discharges from the top of the engine to the radiator. If you leave the cap off and add water as the level drops you should be able to remove the air from the system.
            • Steven B.
              • June 30, 1982
              • 3976
              Gary, I have done my '57 for forty-nine years as John describes and no problems yet. Steve
              • Bruce B.
                • May 31, 1996
                • 2930
                I recently drained the radiator and changed the intake on my 57.
                Put it back together, filled the radiator to the top, drove the car, let it sit and idle for a while, it puked some coolant and since then it runs cool and has not required any more coolant.
                • Dan B.
                  • July 13, 2011
                  • 545
                  What makes you think you have air in the system?? If you fill the radiator, and run the car and it pukes some, that is normal as there is no reserve tank on the early c-1's. Start the engine with the cap off, run it till it warms up and fill coolant to top. Any air will be expelled along with some coolant. Put the cap back on and let it puke till it stops and you are done. Dan
