I am in the process of rebuilding the original brake master cylinder on my 65, (Non-Power) and disc brakes. I have a rebuild kit that includes the following internal parts from front to rear. Valve seat, check valve, return spring, primary cup, piston w/secondary cup, and the retaining ring c-clip. I have heard some discussion that disc brake cars do not use the valve seat and check valve. Is this correct ??, or can someone clarify the correct interior components for this master cylinder. Thanks Dominic Barbieri
