replacement coil - NCRS Discussion Boards
replacement coil
  • Perry M.
    • January 1, 1977
    • 325
    replacement coil
    What is a good replacement coil from Napa for my '63 L84 until I can replace it with a good original 087?
    • 6940
    Re: replacement coil
    Perry, I have a rare coil in my 63, Its a 091 and its not a coil I would like to replace there are a rare part( its in cold storage for now). so I brought one at my local PepBoys which at the time was a Borg Warner. likely made in China today. But works fine. I would say any brand name would work fine.
    • John D.
      • December 1, 1979
      • 5507
      Perry, As Edward said you need an 091 coil on your 63 FI car. Not an '087. Now if you have an old JM it states '087 but the 5th and 6th edition has that error corrected.
      If I didn't have a 087 or an 091 coil for my FI car and was just going to drive it I would probably put in the Delco 64-65 coil like Chevy pushed in the old days.
      202 or 022. I forget.
      091's are major bucks now a days. Be careful as two variations of them. John
      • Perry M.
        • January 1, 1977
        • 325
        Thanks guys. You are correct, I need a 091 coil. As soon as I posted I realized I wrote the wrong number. I confirmed it last night when I checked my JM. I have been looking for the correct coil for some time now.
        • Jim L.
          • September 30, 1979
          • 1805
          Napa Echlin IC12 is a good, all purpose replacement coil. Use it with a ballast resistor.
          Jim
            Jim
            Jim -
            Also known as the Standard UC-12; works great, slightly larger in diameter than a Delco coil. I keep one handy when a "known good coil" is needed for trouble-shooting.
