68 windshield washer pump - NCRS Discussion Boards
  • Dale C.
    • November 1, 1999
    • 844
    Are there any markings on the 68 windshield wiper washer pump? Mine has "made in the USA" on both the metal base and the black plastic cover. I know this pump and motor are not OEM as the pump is black plastic and not that off white. Also do the 3 ports on the 68 come straight out like the 67 or should they make that 90 degree bend and point down like the 69? Maybe Mark Donnally, if you are reading this, might know about the markings on the pump???
    Dale
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 68 windshield washer pump
    Dale I did not inspect my 68's wiper motor or black plastic cover. Where is your "made in USA" information located? Does the black cover have to be removed to view wiper washer pump? I did view my the outlet ports on my 68's original washer pump and they are straight. My 68's pump is the off white mentioned.
    • Dale C.
      • November 1, 1999
      • 844
      Here is a benchmark 68 and you can see the white three ported washer pump that comes straight out. The made in USA is on the black plastic cover that covers the body of the pump. Made in USA is also stamped on the metal base portion of the pump assy. This stamping is located under the pump facing the ignition shield box. When mounted on the car it must viewed with a dental mirror. I took a picture out of the 68 servicemanual but it's not very clear. The line pointing out 'E' Ring intersects some printing on the base where mine says Made in the USA. I have seen others that have delco products and GM stamp on them. The other thing is the direction of the ports. The 68 engine picture shows the ports straight out, like 67, while the 68 service manual shows the 90 degree bend type that is seen on some 69 and later.
      Dale
