window crank Escutcheon - NCRS Discussion Boards
  • Doug R.
    • November 2, 2009
    • 65
    I'm putting new door panels on my 65 coupe. One of the escutcheons behind the window crank does not line up right. Is there any adjustment to them? I installed them on the new panels the same way, with the two closer holes at the top. One panel came out perfect, the other one is off a little. Any one have experience with the escutcheon? Thanks
  • Gene M.
    • April 1, 1985
    • 4232
    Re: window crank Escutcheon
    Doug,
    Are you referring to reproduction panels or originals? Also if repro, were they pre assembled with trim stainless pieces? If the later is the case the escutcheons behind the window crank were not placed in proper position. Kinda too bad now as the holes are already poked thu the vinyl panels. Are they centered with the pre formed contour of the panel? If so the panel its self is off kilter.
    Original panels always fit best, anything else is just a compromise.
