One of the piston seals failed and spilled a puddle of brake fluid on the garage floor. The calipers aren't original since they are 547 series. By reading several threads on this forum, I have come to the conclusion that there is no consensus/standard for cast in or stamped date codes and the date codes don't appear to be judged. I have also learned that I need 545 series calipers. The AIM lists them as 5452266 and 5452267. Are these the cast numbers for the inner halves or outer halves?
When purchasing new front calipers for judging what details should I look for?
Thanx
Thanx
