1967 Ammeter spiking to the negative - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1273
    Hi,
    I just replaced my horn relay and sterring column wiring along with a new headlight switch. Everyting works and the car runs well. However, the ammeter is spiking all the way to the negative and does not move. I checked the connections on the gauge and the horn relay and see nothing wrong.
    I don't have any electrical gauges to test anything, but hopefully the solution will be obvious so that I don't need any analystical tools nor to learn how to use them!
    Any thoughts?
    Jerry
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: 1967 Ammeter spiking to the negative
    Try disconnecting the items you installed to see if this corrects the problem. Then re-connect them one at a time to see if the problem returns. It sounds like you have a direct short that isn't necessarily protected by a fuse
    • Gerald C.
      • June 30, 1987
      • 1273
      I replaced the gauge and all is well. Must have shorted out somewhere in the process
