Can someone tell me what the correct jet and metering rod sizes are for a Carter 3406S or 3461S? 1963 340shp
Carter AFB jet size
Re: Carter AFB jet size
Jim,
Primary jets .104, primary metering rods 16-389 (.060-.069), secondary jets .0689.- Top
Jim, try www.carburetor-parts.com he has some jets listed and may have others.- Top
I found the .104 main jets in an Edelbrock strip kit I had . In looking at their AFB knockoff carbs they use about a .95 jet in secondaries for their street/performance carbs. I think I'll give those a try just to see how it runs. I also several rod pairs in the kit I may try.
This all started when I took the top off my carb and found someone put a secondary jet in one of the primaries and to make matters worse the metering rod was stuck in the jet! GRRRRRRJim Cear- Top
Terry;
FWIW, The company you referred to is also known as "Carburetors Unlimited" is where I too bought many AFB parts, and is the source where I got the jets that didn't measure up correctly.
There are a lot of subtle differences between Carter AFB's and Edelbrock parts.
Stu Fox- Top
