72 Plastic Part - NCRS Discussion Boards
72 Plastic Part
  • Rey S.
    • April 1, 1995
    • 277
    72 Plastic Part
    Does anyone out there know where the plastic (ABS?) under seats seat belt covers can be had (preferably new)? Does the carpet tuck under the edges when installed or does the carpet go on top ? Is ABS repairable ? If anyone has a photo taken of this area showing the covers installed would you be willing to send it to me either on the forum or private message ? -- a picture is worth a 1,000 words.
    Rey Stenhouse
    72 LS-502 Coupe
  • Jeffrey S.
    • May 31, 1988
    • 1879
    Re: 72 Plastic Part
    Rey,
    ABS plastic is definitely repairable. I have used Weld-On brand #1707 which is made exclusively for ABS. To be sure it is ABS, rub a small amount of laquer thinner in an obscure location. If it softens the plastic it is ABS. I have bought this product locally at a large plastic fabrication company in Detroit but I'm certain that it is available on line.
    Jeff
    • Jeffrey S.
      • May 31, 1988
      • 1879
      Re: 72 Plastic Part
      I should have included the following: Manufactured by IPS Corporation, Box 379, Gardena, CA 90248 www.ipscorp.com.
      Jeff
      • Dick W.
        • 10483
        Re: 72 Plastic Part
        SEMS has a plastic adhesive that will work on ABS
        Dick Whittington
        • Rey S.
          • April 1, 1995
          • 277
          Re: 72 Plastic Part
          Hi Dick
          Could elaborate a little more on SEMS.
          Rey
          72 502 coupe
          • Dick W.
            • 10483
            Re: 72 Plastic Part
            Originally posted by Rey Stenhouse (26007)
            Hi Dick
            Rey
            72 502 coupe
            SEM is a leading manufacturer of innovative paints, adhesives and coating products. Our products are developed to exceed your automotive, aerospace and marine repair and refinishing needs.
            Just had a thought, Oatey makes an ABS adhesive for PVC piping. Why would that not work on your part. You can find it in about any hardware store. I like to use the primer when using it.
            Dick Whittington
            • Bill H.
              • August 8, 2011
              • 439
              Re: 72 Plastic Part
              www.semproducts.com
              I've been wanting to try that just for kicks. SuperGlue will adhere to ABS but I'd recommend a backing strip if you use it. And I've used JB Weld in ABS with decent results. jB also has a Plastic Weld but I've only seen it on line.
              • Rey S.
                • April 1, 1995
                • 277
                Re: 72 Plastic Part
                I will definately try this stuff - as you say - easy to come by.
                Rey
                • Rey S.
                  • April 1, 1995
                  • 277
                  Re: 72 Plastic Part
                  Hi Jeffery,
                  I know it's been a while since you sent the info on IPS corp. My comment is -- Are you sure about that Product No. I have searched all of the IPS website and no luck finding a product with that number. Any other ideas?
                  Thanks Rey
                  72 LS502 Coupe
                  • Jeffrey S.
                    • May 31, 1988
                    • 1879
                    Re: 72 Plastic Part
                    Rey,
                    Here is the URL for the Weld-On website ABS adhesive page.
                    I'm sorry that I do not know how to post a link that you can just click on.
                    Jeff
                    • Jeffrey S.
                      • May 31, 1988
                      • 1879
                      Re: 72 Plastic Part
                      I guess you CAN click on it and go there directly. Will wonders never cease!
                      Jeff
                      • Dick W.
                        • 10483
                        Re: 72 Plastic Part
                        Originally posted by Jeffrey Salz (13182)
                        Rey,
                        Jeff
                        Same thing as the Oatey that I posted about earlier.
                        Dick Whittington
                        • Jeffrey S.
                          • May 31, 1988
                          • 1879
                          Re: 72 Plastic Part
                          Dick,
                          The adhesive that is used for PVC piping is not made for ABS which is, I believe, completely different. The adhesive I suggested is made for ABS and that only. I have not tried the Oatey product on ABS.
                          Jeff
