1957 wiring circuit - NCRS Discussion Boards
1957 wiring circuit
  • Jerry B.
    • August 31, 1994
    • 416
    1957 wiring circuit
    I would to comfirm the charging system wiring before I start the car after two years. All my Corvette reference materials are packed for my move. This is my understanding from various discussions from the past - horn relay- horn terminal black bat terminal black s terminal tan -voltage reg.- field terminal dark blue armature terminal brown battery terminal red - generator- armature ? field ? On the generator which terminal is the field and the armature and where the terminals are located. thanks much
  • Rod K.
    • 441
    Re: 1957 wiring circuit
    Can't help with the wiring, but look on the gen case for terminal ID. Mine is stamped "F" next to the terminal nearest the fender (left) and "A" nearest the engine (right), gen mounted on left of engine.
    • Garry B.
      • January 1, 1991
      • 660
      Garry Barnes #18531
      '67 Lynndale Blue Coupe- National TF, BG
      ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
      • Jerry B.
        • August 31, 1994
        • 416
        Thanks Gary for your great photos. Any chance for the voltage regulator photos?
        • Garry B.
          • January 1, 1991
          • 660
          Garry Barnes #18531
          • Garry B.
            • January 1, 1991
            • 660
            Jerry, Here ya go. I hope these help.
            Garry
            Garry Barnes #18531
            • Jerry B.
              • August 31, 1994
              • 416
              Gary, I can not thank you enough. Jerry
              • Garry B.
                • January 1, 1991
                • 660
                You are very welcome. Good luck!
                Garry 18531
                Garry Barnes #18531
