horn sticking - NCRS Discussion Boards
horn sticking
  • William F.
    • June 9, 2009
    • 1354
    horn sticking
    While trying to get my '62's soft top up, I accidently mashed the horn button and the horn stuck on. Removed horn button from behind horn button;horn still on. Had to disconnect horn to stop it. Horn relay stuck closed, maybe? What to do? Help! Haven't been able to get top stretched out enough to clamp down, either;95 degrees; not a good day. Thanks
  • William F.
    • June 9, 2009
    • 1354
    Re: horn sticking
    Come on some of you electrical experts; I need help. After talking to Pirkle, Jr. and tech at Paragon, was told sticking closed horn relay is rare and probably a short somewhere in steering column wiring-something grounding, possibly on bearing surround. What would you check?Thanks
    • Thomas H.
      • August 31, 2005
      • 1053
      Re: horn sticking
      You could disconnect the horn wire where it comes out if the column and plugs into the harness. This would tell you if the problem is a short in the column wiring or another part of the harness.
      2007 Z06, Lemans Blue
      • Dennis C.
        • June 30, 2002
        • 884
        Re: horn sticking
        Is the plunger under the horn button pushed in and stuck or maybe pushed out of its bore? If you really mashed the horn button, it might be possible.
        • Bert L.
          • April 30, 1977
          • 424
          Re: horn sticking
          I second Dennis's suggested cause, it is certainly the most obvious.
          ("I accidently mashed the horn button and the horn stuck on")
