Question: I believe I have heard that the 64 with drum brakes requires a check valve in the brake master cylinder. Reason being that the drum brake shoes had lots of travel and the check valve kept some pressure in the lines so the shoes would not fully retract when the brakes were released; that kept the shoes in close proximity to the drums.
Background: I always wanted a 65 Fuelie but couldn't afford one so about 12 years ago I bought a 64. I was frustrated with the drum brakes so over a couple of years bought disc brake suspension and converted the car to discs about 5 years ago (the drum brake suspension is rebuilt and in plastic bags in my basement so when it comes time to sell the car I can offer to convert back). I didn't want to cut the original brake lines so kept the car as a single circuit system with the master cylinder in use with the drums. I have been warned that using a master cylinder with the check valve will keep pads in contact with the discs and overheat the brakes. I have never noticed a problem but have driven the car very little and only on short drives. I have sourced a correct rebuilt 64 master cylinder but am hesitant to use it for the above reason. Also, the bore is 7/8" and I believe the 65 was 1" (power brakes). If that is the case I will have to find a 1" bore single circuit cylinder w/o check valve and save the 64 unit for when I put drums back on the car. Will appreciate help and advice, Regards Jim B
