Help! 70 BB w/ A/C & P/S-engine was in buckets, so not sure what is correct or if I have all the fasteners and TIM & JG & pictures in restro books not helping much. On all early BB, I have seen (none with this option combo) the top RH bolt on the water pump is a stud, which does not seem to ever be used for attaching anything to. However, on this 70, that same type stud is used on the top LH side for one of the alternator brackets; unique, when equipped w/ P/S; than another longer stud is used bottom LH for the idler when optioned w/ P/S. For this application; would you expect to still see the stud on the RH top, installed and painted at engine plant? I would assume the RH top stud would have been installed & painted at Tanawanda, but the studs on the LH side were installed at St. Louis (based on options), therefore not painted. Pictures/drawings in the AIM under C-60 do not have the stud on top RH. So, was the normally Tanawanda installed stud, then removed when option C-60 was applied, and therefore, the replacement bolt would be un-painted: and if so, was it cad or phosphate?
On a similar note: when equipped with A/C, there were 2 vac advance steel lines, hooked to the Spark Control Solenoid. These lines are held by a single clip that had double line provision (2 springs jaws), were as the 71 model used a single line and 2 single line provision clips. Would the attaching bolt holding the clip (one of the intake manifold bolts) have been replaced in St. Louis due to option and therefore it would be un-painted-cad or phosphate? ALSO: does anyone know where I can find one of these double line provision clips???????????????????????????
Mike
Mike
