I am considering a 68 convertible L79 car. The car originally was LeMans Blue with M Blue interior. The seller has been gathering parts and resorting the car back to original using no reproduction parts. However the seller was in the process of changing to black interior. So far the dash has been dyed black, and shift area, he located excellent door panels (black), like new black seat belts, and a few other parts. It still needs seat covers, and carpet. Questions: 1. Is dying the dash and panels to blue a good idea? They are in great shape but the dash looks like it was dyed at least twice. Can it be cleaned or stripped? 2. Can I get replacement seat belt material. 3. Are the 68 and 69 dash pads, the same (other than map pocket) and is a reproduction any good for judging? thanks cal
To dye, reproduction or used interior
Re: To dye, reproduction or used interior
The PO of my 68 had dyed everything black. I used SEM automotive interior dye and returned everything to the original dark blue.
If you attempt to strip it you will want something which will not eat vinyl. I did not strip my panels, but I did use lacquer thinner on a rag to remove some of the stuff....the dash looks like it was dyed at least twice. Can it be...stripped?...
Driver's dash has the ignition key in it for 68s....Are the 68 and 69 dash pads, the same (other than map pocket)...
- Top
You cannot dye vinyl. It can, and is colored all the time. (elastomeric paint).That makes it removable, since it's a surface finish and doesn't peretrate the vinyl. I've used lacquer thinner VERY carefully, and washed with soapy water as I went. Leaving lacquer thinner on too long will melt the vinyl- Top
