54 Corvette 6volt charging issue - NCRS Discussion Boards
  • Joe M.
    • July 31, 2005
    • 12
    I think my generator is not putting out enough as the battery does not seem to be charging so I tested it on the car. I'm looking for feedback on my findings. I disconnected the field and armature wires to test it. I started the car with a meter on the generator. At idle about 1-2 volts. At 2500rpm approx 3-4 volts. At 4500rpm it came up to 5.7 volts max. Could not get it higher than that. Shouldn't the generator put out more than 6 volts in order to engage the regulator and charge the battery? Any help is much appreciated.
  • Chris S.
    • January 1, 2000
    • 1064
    Re: 54 Corvette 6volt charging issue
    connect everything up....
    under load - lights on, etc.... high idle - should put out 7.3v
    most 12v systems charge at 14.4 - so around 1/2 that for 6 volt.....
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Dan D.
      • November 5, 2008
      • 1323
      Joe, you have to ground the field terminal in order for the generator to charge. Try that and measure the voltage at the armature post. It should be high. -Dan-
