69 oil capacity - NCRS Discussion Boards
69 oil capacity
  • Paul K.
    • February 1, 2002
    • 160
    69 oil capacity
    owners manual for 69 corvette 427 shows 6 qts with a filter. I know the oil pan is correct, but gauge shows half quart high with 5 and 1/2 quarts. Should I put in the 6 qts anyway? I am using the PF25 filter
    Re: 69 oil capacity
    Paul-----
    The oil capacity with filter change for all Corvette big block applications is 6 quarts. Are you sure you have a correct dipstick and tube? Are you sure the car has a correct Corvette oil pan?
    • Paul K.
      • February 1, 2002
      • 160
      Re: 69 oil capacity
      I have the correct oil pan, but seams to me the filter would not hold a quart,
      • Paul K.
        • February 1, 2002
        • 160
        Re: 69 oil capacity
        Joe - the oil pan matchs to 68-69 judging guide, do you know if a PF 25 oil filter actually holds a quart??.
          • 15573
          Re: 69 oil capacity
          A PF 25 filter will not hold an entire quart of oil. A PF 35 will. I believe the PF 25 holds about 1/2 to 2/3 quart of oil, but I have never attempted to measure it accurately.
          Here is a lot more info ont he subject, byut even this thread is not all encompasing:
          http://forums.corvetteforum.com/engi...4-pf1218s.html
            Re: 69 oil capacity
            Paul-----
            A PF-25 does not have a 1 quart capacity; it's about 2/3 of a quart. However, the amount it is short of a quart would not explain the amount of difference you reported( i.e. "half a quart high with 5-1/2 quarts").
            What color is the plastic "button" on the end of your dipstick finger loop?
              Re: 69 oil capacity
              Terry------
              There's at least one error reported in the thread you linked. The PF-35 is no longer available from GM and has not been for quite a few years. It was replaced by the PF-1218 which is somewhat shorter than a PF-35. The PF-35L remains available from GM, though.
              • Paul K.
                • February 1, 2002
                • 160
                Re: 69 oil capacity
                Mine is the long curved handle for the air cond.046.JPGI confident I have the right oil pan
                • Paul O.
                  • August 31, 1990
                  • 1716
                  Re: 69 oil capacity
                  Paul
                  If your car is a 10,000 S/N or earlier your filter should be a PF-29 which is a longer filter then a PF-25. It is similar in length as a PF-35.
                  • Paul K.
                    • February 1, 2002
                    • 160
                    Re: 69 oil capacity
                    serial number is 20830
                      • 15573
                      Re: 69 oil capacity
                      Terry------
                      All of those posts are from 2003, and I was remiss in not pointing that out. As the parts business goes now days it is a full time job keeping up with the marketing changes, and of course information from a decade ago will be, well, dated.
