1986 Radio Antenna to Remove and Replace - NCRS Discussion Boards
  • Gregory G.
    • July 31, 2001
    • 203
    Gentlemen,
    Anyone have a step by step procedure to remove and replace the entire motor assembly antenna from my '86 coupe.
    Greg
  • Don G.
    • March 1, 1989
    • 251
    Re: 1986 Radio Antenna to Remove and Replace
    Greg The following is from the 1986 Corvette Shop Manual Section 9B-11 : 1. Disconnect battery ground 2. Open hatch and remove rear trim panel 3. Disconnect power antenna lead to relay 4.Remove left side trim 5. Remove luggage shade 6. Remove carpet trim, left side, and pull back carpeting 7. Remove left side trim panel 8. Raise vehicle 9. Remove inner fender screws and brace open to gain access 10. Remove antenna ground strap 11. Disconnect plastic nut at top of mast. 12. Remove antenna bracket nuts 13. Remove power lead and antenna lead through body 14. Remove antenna 15.Transfer bracket and ground strap.16. For installation reverse removal procedure. Good Luck Don
    • Walter G.
      • May 31, 1989
      • 166
      I did this project on my '84 a couple of years ago-not a fun adventure. I found some detailed instructions with pics on the 'net which helped.
      (just Google '84-'86 Corvette antenna replacement or similar and you should get some links) Even with the details provided it was tough getting at some of the attaching points. Having a lift would make things somewhat easier. I just had to replace the nylon ribbon in mine, as the motor itself still worked, but you still need to remove the whole unit for a repair. The luggage shade replacement was difficult as well; seemed to be logical, but frustrating. Be sure you record/photograph how everything was taken apart-ask me how I know...
      • Gregory G.
        • July 31, 2001
        • 203
        Thank you Don and Walter.
        Greg
