1957 Corvette temp and fuel guage wiring - NCRS Discussion Boards
  • Jerry B.
    • August 31, 1994
    • 416
    The AIM is very confusing concerning the wiring of the temp and fuel guages. Would some post a photo of the back side of these two guages. Thanks in advance for your time.
  • David S.
    • December 1, 1982
    • 310
    Re: 1957 Corvette temp and fuel guage wiring
    DSC00883A.jpgDSC05654A.jpgHi Jerry,I have attached a few pictures from my 57 bowtie. This should tell you what you need Dave
    • Jerry B.
      • August 31, 1994
      • 416
      Great pictures.
      • Jerry B.
        • August 31, 1994
        • 416
        Hello again Dave. Could you forward a photo of your battery guage from your BOWTIE car. Lucky you. thanks Jerry
        • Brooks G.
          • December 1, 1978
          • 286
          Jerry, I had Milton Hood from Woodstock, Georgia to rebuild and recalibrate the gauges for my 1956 Corvette. He told me when you are laying under the dash wiring the gauges to be sure to put the hot wire (red) on the lead closest to the driver's door. This worked for me. I wish you the best of luck with your restoration. Brooks Glover (2141)
          • David S.
            • December 1, 1982
            • 310
            DSC00855A.jpgDSC06460A.jpgJerry I have attached a few pictures you requestedDave
            • Jerry B.
              • August 31, 1994
              • 416
              Hello Dave, I hope I am not wearing out my welcome. Needs two more pictures. one fuse panel and full battery guage. This car refuses to start fuel is ok and starter turns over--no spark? It is starting to get to me!
              • David S.
                • December 1, 1982
                • 310
                DSC04746A.jpgDSC06460A.jpgDSC00855A.jpg Hi Jerry I have attached a picture of the fuse block also the oil and Battery guage. I did post it yesterday at 9:53 Pm but failed to ID it properly. Jerry are you sure you have a good coil and coil wire ?? Dave
                • Jerry B.
                  • August 31, 1994
                  • 416
                  Hello David, here I go again. Having problems with the ignition switch wiring setup ,double pink wire location and single pink wire location , resister wiring ,and coil wiring. Your photos have been very helpful. I am taking one step forward and five steps backwards. I have a AIM resource but my copy is very poor for it has been reproduced many times and it is very hard to read. All my colored wiring diagrams are packed. You have been so kind to sent me some great photos. Would u advise which of the two green wires and the brown wire location on the resistor. One of the green wires goes to the coil and the other goes to the resistor. This old car has me talking to myself. Your idea on checking the coil was good but I think I have the wiring so ---up that, I should start over with the basics.
                  • David S.
                    • December 1, 1982
                    • 310
                    DSC05643A.jpgDSC00606A.jpgDSC00629A.jpgJerry picture of ign switch should be east to see. Ballast resistor single green wire from ignition harness on one terminal. Brown wire from ignition harness and brown from wiper motor on the other terminal. Coil Double green from ignition harness along with a black from radio capacitor ( If radio in car)The other terminal is wire from Dist. Should be easy. Let me know if you need more info Dave
                    • Jerry B.
                      • August 31, 1994
                      • 416
                      Thanks to all for replying to my request. She has been laid up for over 16 mounths and with your help , the old girl came back to life. All were very helpful and pictures are worth a thousand words. Again THANKS
                      • David S.
                        • December 1, 1982
                        • 310
                        Jerry when you say the old girl came back to life. Does that mean you got the old girl running. If so what did you find as the problem Dave
                        • Jerry B.
                          • August 31, 1994
                          • 416
                          Hello David, the old girl became a spring chicken yesterday. I had two wires incorrectly placed, the black ignition wire on starter switch and one of the green wires on the resistor which should have been mounted on the coil. I own you a couple of beers. THANKS AGAIN Jerry
                          • David S.
                            • December 1, 1982
                            • 310
                            That's very good news Jerry. Glad I could help Dave
