I wanted to ask if anyone has noticed a difference in the function of aftermarket vs GM heat riser valves and there springs not allowing valve opening after engine warm up.
I believe my 67 has a aftermarket H/R valve and I am experiencing that after warm up the valve stays just about closed. With slow cruising the gasoline in the accelerator pump vaporizes and makes driving difficult so I wired the valve open. I painted the valve with the exhaust manifolds a long time ago with that high heat exhaust paint so the thermostat spring is painted also and I wonder if that's the reason why it does not expand and open the valve more when hot. Could the painted spring be a problem?
All comments are appreciated
