Front Springs - NCRS Discussion Boards
Front Springs
  • Rob M.
    • April 30, 2003
    • 657
    Front Springs
    Okay,
    I've read the archives (lots of posts) about front springs. I have a couple of questions that weren't clear from the archives. First, is there any reason I should not media blast original springs to clean them up? Second, how does one replicate the finish? The JG states that they were coated with a rust inhibitor and have a black appearance. I saw that using gun blue coating is close, is that my best bet?
    BTW - 66 327/300
    Thanks in advance for your thoughts and experience,
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
  • Michael H.
    • January 29, 2008
    • 7477
    Re: Front Springs
    Originally posted by Rob Myrick (39795)
    Okay,
    BTW - 66 327/300
    Rob,
    The original final process during manufacture of new springs called for "shot peen the entire surface".
    About the best you can do for a reasonably correct finish/look would be to have the springs cleaned in a tumbler. That will probably come close.
    Glass beading will result in a dull finish that is too light, or white. The original finish/color was silver and slightly reflective.
    Springs installed on the assembly line were not coated with anything that was black, as mentioned in the JG. I don't know where that info came from.
    The light coating that was applied was a form of cosmoline and was nearly transparent. It was for rust prevention.
