70 speedometer cable - NCRS Discussion Boards
  • Joseph M.
    • June 30, 1999
    • 334
    Does anyone know if a 70 speedometer cable is available from GM? If not, who makes the best repro? I'm having trouble getting my speedo to function. I know the speedo works as it has been rebuilt and can be spun manually, but when the cable is installed it appears to be too short. Thanks.
    Re: 70 speedometer cable
    Joseph------
    Assuming that you are talking about a 4 speed application and assuming that the proper cable is a one piece cable 72" in length, the current GM speedometer cable assembly (casing + cable) should be GM #88959478. There have been FIVE supercessions from the original part number so a lot could happen over that sort of history, but this is the best I can come up with.
    • Joseph M.
      • June 30, 1999
      • 334
      Joe, thanks for researching this for me. I'll check and see if the cable is still available.
      • Harry S.
        • July 31, 2002
        • 5258
        Joe, if the inner cable is too short just replace the inner cable. Advanced Auto Parts has an inner-cable kit for $9.09. Their part number is 03368. The inner-cable on my 63 just broke and it took no time to cut and crimp the new inner-cable.
        All you need is the length measurement for the inner-cable.
        • Joseph M.
          • June 30, 1999
          • 334
          Harry, thanks for that info. I didn't know that kit was available.
            Joseph------
            I assumed that you meant the complete cable assembly was too short (although I couldn't figure out how that could be the case if you were just re-installing the assembly). As a matter of fact, I can't figure out how the cable component itself could be too short if the assembly was previously installed and performed without problem.
            You can obtain a "one size fits all" inner cable kit under current GM #88960343. This cable is cut to length and the speedometer end then crimped on using a little tool supplied with the kit or has a plastic end which is glued on. Personally, I don't like either style. My choice is to go to a speedometer shop and have them make up a cable of the correct length. It doesn't even cost that much.
            Keep in mind that the cable can only be removed from the casing at the speedometer end.
            • Joseph M.
              • June 30, 1999
              • 334
              Joe, prior to the restoration process I did not drive the car so I can't confirm that the speedo woked. Since posting I've located a 72 inch inner cable from a 70 4spd. It has a black plastic end secured to the cable. Now my question is does the black plastic end go into the transmission or the speedo? Thanks.
                Joseph-----
                If it's a plastic end, the inner cable was replaced at some time. The plastic end goes into the speedometer. The other "squared" end goes into the transmission.
                • Mark H.
                  • December 27, 2007
                  • 135
                  My '71 M20 also had an intermittent speedo problem. The cable was barely sticking out of the speedometer end, and had about an inch and a half on the transmission gear end. I pulled the actual cable out about 1/2 an inch on the speedo end and it has worked flawlessly for 6 years. Mark
