Thought I'd start a new thread re my inoperative battery meter.
Hasn't worked since I have owned the car for 10 years. I only get a small deflection when the headlights are on. My battery is 6 years old so I assume my charging system is working.
Here is what I have done a few years ago before I gave up.
Cluster rebuilder says gauge is Ok. I also did the AAA battery 1.5 volt flash test and got movement of the meter so I am ruling out the meter itself.
I cleaned the bulkhead connectors and I get voltage at both legs of the meter so no open circuits there. Check connections at horn relay
I read in the archives that the battery meter reads the voltage drop across the 10 ga red wire that runs from the solenoid B terminal to the alternator B terminal (then to the horn relay). I removed the connection at the solenoid and sandpapered the ring terminal where both the #10 and #18 black wire are terminated.
Today I took some voltage measurements
battery 12.7 volt at battery terminals (engine off)
With ammeter connector disconnected
12.38 volt to ground each leg ( eng off)
13.8 volt to ground each leg (engine at idle) maybe 13.7 with headlights on
This tells me no open circuit in either the #18 black wire to solenoid or the #18 B/W that goes to the horn relay
Leg to leg at ammeter connector
0 volt (eng off)
.03 volt (eng on)
Any ideas of where to check next?
0 volt (eng off)
.03 volt (eng on)
