65 BB core support / frame shims - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    I am installing a new front end consisting of a GM upper surround and side fenders . My gap is getting very tight at the front between the surround and the side fender .The frame and the core support all seem to be straight . I have a good hood gap all around . I still have all the welded shims between the frame and the lower core support . If I add about 1/4"of shims to the right lower side I get a good gap between my lower fender and the surround. That also levels my core support . and gives me the same distance from the floor to the head lamp area. My question is did any one else need to add shims to there core support ?
  • Tony S.
    NCRS Vice President, Director Region VII & 10
    • April 30, 1981
    • 969
    Re: 65 BB core support / frame shims
    Bill, the only shims that I added were between the sides of the cores support and the inner fenders.
    Tony
    Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
    Original member of the Kansas City Chapter, est'd 07/11/1982.
    Member: 1965 and 1966 National Judging Teams
    Judging Chairman--Kansas City Chapter.
    Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
    • Wayne W.
      • April 30, 1982
      • 3605
      After 48 years, lots of water over that dam. There is no guarantee the same amount of shims are needed today. You should jack the frame up and level it on jack stands, then level the body to match. Then you will know if your measurements are correct.
