1965-67 big block dip stick?? - NCRS Discussion Boards
  • Kevin P.
    • November 1, 1975
    • 86
    I have 2 big block dip sticks with salmon (pink) plug in handle both are stamped with add/full but one is stamped with part number 3860316 also they DO NOT have the dimple.Are these correct for judging and what are they worth? Kevin (775)
  • David L.
    • July 31, 1980
    • 3310
    Re: 1965-67 big block dip stick??
    Kevin,
    I have many dipsticks in my collection but none for 1965-1967 BB models (GM # 3860316 where A = 17 13/32", B = 18 1/8"). However, I have had several original assembly line 1965-1967 Corvette 327 dipsticks (GM # 3739830) that were stamped "ADD", "FULL", "ENGINE OIL" and "M" (where the "M" sometimes looks like an upside "W"). I would assume that the 1965-1967 BB models would have the same stamping but would differ in length. According to the 1967 AIM "late" (revision record drawing 3/3/67) 1967's w/L36 used dip stick 3925520 where A = 17 13/32", B = 18 1/2".
    I believe that the 1969-1971 dipsticks were stamped "ADD", "FULL", "USE GM6040 M QUALITY MS OIL".
    I believe that the 1972-1973 dipsticks are stamped "ADD", "FULL", "USE SE ENGINE OIL" and "M".
    The "over the counter" 3862730 dipsticks that I bought in the 1980's were stamped "ADD", "FULL", USE SE ENGINE OIL", "3862730", and "M".
    Do your dipsticks measure as follows: A = 17 13/32" and B = 18 1/8"?
    The link below might help.
    Dave
    https://www.forums.ncrs.org/showthre...25520+dipstick
