Since it's been hot this week I was wondering if anyone with a C2 or C3 and an IR gun could run a heat test for me. I'm interested in the temperatures on the input side and output side of the hot-water-shutoff valve.
Take you car for a run with the AC on, stop, leave it running with the AC on and check the temp on the input side and the output side of the hot-water-shutoff. On the output side check as close to the firewall as you can get.
I believe my hot-water-shutoff is stuck a bit open and is sending hot water into the heater core all the time. The affect is to warm all that nice cold air generated by the AC unit. My freon is OK, already checked that.
