I had started out for NYC last week to join the Scandinavians in a send off of starting their Lincoln Highway Tour 2013.
As you recall, my pedal was heading left. Well about 3 miles away from home the pedal came off. Tow truck brought it back home and I was in my other car and off to NYC. I was fortunate not to have it break in the middle of CT or MA.
Once back home I took on the job of repairing the pedal. I ordered a new pivot rod and had it welded back on to pedal. The following pictures will give you an idea what it looks like to do the repair.
First you have to take out the seat and steering column 1/2 hour
You have to take off the clutch spring and cover along with the column hardware . You can see the column hole in firewall . Also notice the bolts that hold the master brake cylinder and two above hold the pedal assembly to firewall
Column out complete , do not take apart , just pull out after removing under cluster supports.
Parts laid out on table. column parts in order , pedal assembly
Broken pivot rod and replacement rod inserted in pedal
Original Capacitor for brake lights
Pedal installed into assembly
The bushings used are the plastic ones use also in the headlights and convertible top latch assembly. Just re grease and insert pedal pivot rod and re-clip
All done . Total time about 4 hours without rushing.
