Loose rear spindle nuts on C2 - NCRS Discussion Boards
  • Gary R.
    • April 1, 1989
    • 1796
    Re: Loose rear spindle nuts on C2
    Just some thoughts from the many arms I rebuilt. It is not all that uncommon to find large mistakes made to arms by vette shops, garages, and dealerships. The experience and job skills of the mechanic are more important then where the job is done. One question I have is with your terms, runout refers to rotor runout through 360* of rotation. A loose spindle nut will not have much effect on runout but it will on bearing endplay which I believe is what you are referring to. I have seen "rebuilt" arms come to me with no shims just the spacers, others reuse the same shims and press them together- not good. If you are using disc brakes you want the bearing end play set to 0015-002" and rotor runout under 003". If you are using drum brakes there is no runout to be concerned with but the endplay should still be checked. The concern I have is you found poor work, so how good is the rest of the work? If it were mine I would be breaking them down to do them right. It's better to install new USA Timkens now while they are still made here then to risk a bearing failure later. Just my opinion.
    • Randall M.
      • July 24, 2011
      • 8
      Gary,
      Thanks for the sound advice. I will buy some USA Timken Bearings and hold on to them in case I need them in the future. I am not likely to disassemble the rear arms right now because I don't have any of the tools required, the current bearings are not making any noise and seem to function normally. I am not disagreeing with you, I just don't have the time or resources to verify with a disassembly right now.
      Randy
      • Gary R.
        • April 1, 1989
        • 1796
        #18
        Hi Randy
        I would hope the last guys greased and set them up correctly. If they are good now just keep an eye on them. You will know if they are not correct in short order. Good idea to get the bearings now and hold on to them, just don't store them in humid areas or drop them! If you are going to Carlisle next month I will be holding a open discussion for an hour on diff's, arms, and boxes on Friday at 2:00pm building R.
        • Randall M.
          • July 24, 2011
          • 8
          #19
          Gary,
          Thanks again for the advice. I think the bearings are okay, I have already driven the car over 2000 miles in 2 1/2 years of ownership and I don't know how much the previous owner drove it with the new bearings. With that many miles on them, I would imagine they would have already failed if they were not greased or shimmed properly. I am planning on attending your tech session and actually showing my car in the Year of the 63' display at Carlisle. With all that said, I may have to cancel my trip because my wife's due date is 5 SEP. It may not be a good idea to attend Carlisle in the same timeframe as my first daughter being born! We will see though maybe I will figure away to pull it off.
          Randy
          • James B.
            • March 1, 1985
            • 217
            #20
            Gary:
            Would you readily have the part numbers and source for the Timken Bearings so I may secure a purchase also?
            Thanks.
            James
            Hi Randy
            • Gary R.
              • April 1, 1989
              • 1796
              #21
              Yes I have all the numbers and will post them tomorrow.
