"1115082" and "083" Delco-Remy Ignition Coil Identification - NCRS Discussion Boards
  • David L.
    • July 31, 1980
    • 3310
    In my collection of Delco-Remy ignition coils I have two coils that I am trying to identify.
    The 1st coil is embossed "1115082" and "12-V" about 3/4" to 1 1/2" from the bottom. The "Delco-Remy" is also slightly smaller than the rest of my Delco-Remy coils. Could this be original equipment on a 1955 Chevrolet or other 1955 GM model?
    The 2nd coil is embossed "083" and "12V" near the top of the coil. Based on my research on the web I found that the 1115083 coil is possibly original equipment on 1956-1957 Chevrolets.
    My 1957 Chevrolet Parts Catalog (Mar. 1957) lists GM # 1115087 in Gr. 2.170 as the service ignition coil for 1955-1957 Chevrolets 12 volt (exc. dual 4BC).
    Dave
  • David L.
    • July 31, 1980
    • 3310
    Re: "1115082" and "083" Delco-Remy Ignition Coil Identification
    • William C.
      • May 31, 1975
      • 6037
      According to my reference 1955-56 Chev used the 380 coil and V8 used 087. '380- '48-52 Cadillac (6 volt systems) 082 used on '53-up Buick (12V) 380 used on pre-52 Buick, '48-52 Olds (6V) 082 used '53-55 Olds 12 volt. Probably more, but you get the drift...
      Bill Clupper #618
