L-88 Valve Spring TSB
Re: L-88 Valve Spring TSB
I sure if the "exhaust valve hit the piston top at extremely high rpm" it would take more than this TSB to fix
the problem.
- Top
I have the TSB's (actually one original and then a revision) that show all the engines for 66 production and the L-88 is included although it wasn't listed specifically as L-88, but as Heavy Duty..
The revised issue TSB from Feb 22, 1966 shows 425 hp 427 in the Corvette as the familiar IP code, but it also lists Heavy Duty code IT and with aluminum heads as IU.
- Top
