The ends of the 90 degree copper elbow are different diameters. Can anyone tell me which diameter goes where? Thanks!
C1 (1958) Heater Copper 90 Degree Elbow
Re: C1 (1958) Heater Copper 90 Degree Elbow
5/8" end to a short hose to the heater core, 3/4" end to the 3/4" hose to the water pump. This hose goes through the firewall into the elbow with the clamp inside the firewall. There should be a grommet for the 3/4" hose in the firewall, but reproduction ribbed hoses are too large wall thickness so you may not be able to use the grommet.Attached Files- Top
Affirmative with the hose wall thickness and not fitting through the grommet. But all I did is remove some of the rubber from the grommet ID. Used a grinding bit in an electric drill - did the trick. Did not touch the fiberglass. The hose OD is not a lot larger. It does not take much to make it fit. -Dan-5/8" end to a short hose to the heater core, 3/4" end to the 3/4" hose to the water pump. This hose goes through the firewall into the elbow with the clamp inside the firewall. There should be a grommet for the 3/4" hose in the firewall, but reproduction ribbed hoses are too large wall thickness so you may not be able to use the grommet.- Top
Dan, I was thinking of doing that to my grommet to but my ribbed (no GM stencil type)hoses from CC fit tightly through the hole in the firewall. I don't think it'd work for this one.Affirmative with the hose wall thickness and not fitting through the grommet. But all I did is remove some of the rubber from the grommet ID. Used a grinding bit in an electric drill - did the trick. Did not touch the fiberglass. The hose OD is not a lot larger. It does not take much to make it fit. -Dan-
Rich- Top
