70 seven blade fan - NCRS Discussion Boards
70 seven blade fan
  • David L.
    • July 31, 1980
    • 3310
    #31
    Re: 70 seven blade fan
    Originally posted by Gary Haftel (49128)
    My July 69 427/390 AC car has a 3955182 fan. Pics attached. Gary
    http://imageshack.us/photo/my-images/854/lhbs.jpg/
    Gary,
    I only can see part pf the date code ("D6") in your photo. I assume that it is actually "D69" (April 1969).
    Dave
    • David L.
      • July 31, 1980
      • 3310
      #32
      Originally posted by Dino Lanno (27248)
      I had a low mileage unrestored original 1970 base motor with AC, which had a 5 blade and judging guide stated 7 giving points deductions.....the assembly was never touched from the factory it was June car
      I believe that part substitutions were made to keep the assembly line moving.
      Do you have the original fan-clutch?
      If so, is it the bar-strip type (Schwitzer) or the coil type (Eaton or Delco) and is the diameter 6" or 7 1/4"?
      Dave
      • Gary H.
        • June 8, 2008
        • 308
        #33
        yes, D69
        Gary
        • Clark E.
          • March 1, 1991
          • 163
          #34
          Thanks Dave...I "assumed" the "66" was a "99" as the #'s were facing the same direction as the other hub markings. I also discovered upon re-installing the fan the information can't be read with the fan attached to the clutch. Duh?? I'll check the clutch information and advise. Interesting that Jim and Dino also have 350/300's w/ air that have what appears to be factory installed 5 blade fans. Must be others out there. Would be helpful to know the date stamped on the clutch bolt mounting flange...Clark
          • Bob I.
            • November 9, 2006
            • 265
            #35
            Dave,
            Picture of the fan blade with the date code 00047
            Bob
            • David L.
              • July 31, 1980
              • 3310
              #36
              Bob,
              Fan # 3955182 was still available in November 2001 for $115.33 (list price). I have no idea when the fan was discontinued.
              Maybe your "00047" fan is dated July 2004.
              Dave
