I am looking for recommendations for the best way to protect the front end. I have read about plastic films and other products found at sites like Corvette Central. I just had the 66 repainted and want to protect it when I drive. Thanks for any recommendations.
What is the best Nose cover for long trips
Re: What is the best Nose cover for long trips
3M blue painters tape has worked for me in the past. 3 or 4 inch wide. Start at the hood line and go down towards the nose. If you want to do bottom side start at bottom and work up. Last runner should go over the nose tip and cover that last layer of tape on the top and bottom. Good luck.John Seeley
67 Black/Teal
300 hp 3 speed coupe
65 Maroon/Black
35k mile Fuelie coupe- Top
Rod, I have heard that static cling clear plastic wrap works , they make a heavier gauge than the store bought stuff, generally sold at the wholesale stores like Costco. and maybe the painters tape in a few spots to help keep it tight. EdNew England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Bill Strobel
Owner Independent Towing
Fayetteville, NC
1979 Corvette White/Red L-82 4 spd
Only 4,200 miles
Do It Right or Don't Do It At All- Top
Either the 3M Paint Defender or something similar is being heavily advertised right now on TV. The commercials have been shown during My Classic Car, Counting Cars, and Fast 'N Loud, to name a few. I think it comes in an aerosol, but I don't remember, as I stopped watching commercials after I got a DVR.- Top
You are correct Paul, it is an aerosal can. I have a friend who drove his black '98 form TX to Upper Penn. of MI. for a month and back to TX with the 3M Defender on the nose, on the leading edge of rear fenders, lower body behind rear wheel openings, and lower body behind front wheel openings. He had a couple of stone marks on the clear coating but no marking under the product. Mike is very particular and removes his wheels and cleans the inside o fthem each Saturday when he washes the car.Either the 3M Paint Defender or something similar is being heavily advertised right now on TV. The commercials have been shown during My Classic Car, Counting Cars, and Fast 'N Loud, to name a few. I think it comes in an aerosol, but I don't remember, as I stopped watching commercials after I got a DVR.
I have used bras on two Corvettes and they do mark the paint, especially around the clips. I will never use one again.- Top
And what kind of paint is it?I am looking for recommendations for the best way to protect the front end. I have read about plastic films and other products found at sites like Corvette Central. I just had the 66 repainted and want to protect it when I drive. Thanks for any recommendations.
I have "clear bra" on the whole nose, rockers, lower door, and front of rear quarter of the '08, but it had BC/CC that is hard as rocks so I can pull the plastic off whenever I want. If your paint is a catalyst cured paint use what you want, but if the paint cures by evaporation you will have to wait a while, maybe a long while, before covering it. See why I asked what kind of pint it is?Terry- Top
Your post reminds me of the 1990 Williamsburg National Convention. Wendel Hans from CA drove his '69 435 from and back to CA with blue tape covering all subject areas. He scored over 97 without driving points and got his Duntov. You can drive and show them too.3M blue painters tape has worked for me in the past. 3 or 4 inch wide. Start at the hood line and go down towards the nose. If you want to do bottom side start at bottom and work up. Last runner should go over the nose tip and cover that last layer of tape on the top and bottom. Good luck.Dick Whittington- Top
Rod,
In the past I have used car wrap. The stuff that racers and others use as paint.
The reason it so nice is they can print it almost the same color as your car. You get a heat gun and stick it down. It comes off very easy and does a great job of protecting your paint.
Monte- Top
