Where can I find pictures of the 2 drain plugs at the bottom of the block? And how many quarts of antifreeze does a big block take? Thanks. Dutch
Changing antifreeze 1966 427 L36
Re: Changing antifreeze 1966 427 L36
Drain plugs are lower part of the block, right above oil pan. Should the engine have stock exhaust manfold, drivers side drain plug will be slightly hidden by the exhaust manifold as well as difficult to get out. Capacity totally empty....radiator and block will be 5 to 6 gallons of fluid, closer to 6. A 50/50 mix is perferable.- Top
The passenger side has the allenhead plug in the middle and a 4 sided plug at the far end. The drivers side has 3 allenhead plugs with a 6 sided plug in the middle above the allenhead plug. Is this norm?[ATTACH=CONFIG]47458[/ATTACH][ATTACH=CONFIG]47459[/ATTACH][ATTACH=CONFIG]47457[/ATTACH]- Top
Harry -The passenger side has the allenhead plug in the middle and a 4 sided plug at the far end. The drivers side has 3 allenhead plugs with a 6 sided plug in the middle above the allenhead plug. Is this norm?[ATTACH=CONFIG]47458[/ATTACH][ATTACH=CONFIG]47459[/ATTACH][ATTACH=CONFIG]47457[/ATTACH]
The square-head plug directly below the fuel pump doesn't get touched - that's where you remove/install the fuel pump pushrod on a big-block. The two you want for draining the coolant are one on each side, just above the pan rail.- Top
I am still researching this event and waiting for my waterpump from Bill. John, on the left side of my block there are 3 allenheaded plugs, 1 on either end of the block and 1 in the middle, right below a 6 headed bolt as in the 3rd pic. Is that the drain bolt or do I use the allenhead plugs to drain? On the right side I only have the allenhead plug. thanks Dutch- Top
Here is a photo of a 67 427 coolant drain plug location. Both sides are in a similar location. Steve.Attached Files- Top
Harry, the small allen head plugs on the drivers side of the L36 are oil galley plugs, the larger hex head plugs one on each side go into the water jackets.- Top
