Hi Everyone - I have one headlight (low beam) that is very dim. Is it the light or maybe a connection? Thanks
71 Dim Headlight
Re: 71 Dim Headlight
Could be either. There are many connections. You could throw parts at it (replace with a known good bulb); or you could learn to check for voltage drop. This is a handy skill to learn. I guess it depends on whether you are into automotive repair for the long haul, or if this is a one time thing. Try googling "voltage drop" and see if you want to take it on.Terry- Top
[QUOTE=Peter Bouza (34477);670961]Hi Everyone - I have one headlight (low beam) that is very dim. Is it the light or maybe a connection? Thanks[/
Pete,
Check both your ground connection and the connections to the back of the headlights. Make sure they are clean and tight.
Dennis- Top
And to add to Dennis' comment, add some dielectric grease to the bulb contacts to help prevent further corrosion.Kurt Geis
Chairman, Midway USA Chapter
Targa Blue 1972, Top Flight and Duntov Award, 2014
Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
Arctic White 2013 60th Anniv Special Edition Conv.- Top
