54 firewall grommets, which goes where? - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    This might seem silly and easy to figure out but........Its obvious where the oe with 3 holes go. I have 12 with a 1/16th inch hole, Im thinking hood cables. Two which is 1-7/8 overall sponge with a 3/4 inch hole, wire harness and e-brake handle? Another with an overall of 1-7/8 with four of which two are raised, the orter two dont go thru the rubber. I cant seem to see which ones go where. Oh what fun. Thanks for any help. Someone else must be wondering also. Guy
  • Eric F.
    • June 30, 2003
    • 319
    Re: 54 firewall grommets, which goes where?
    Guy, Here's a photo that shows a couple of their locations and what goes through them. This photo is from a Duntov car. IMG_0742.jpg
    The ones that don't have holes allow you to modify them for the desired application. There are two (one on each inner fender) for the wiring harnesses that go to each headlamps. There is one that has 3 holes for washer hoses, which mounts on the passenger side of the firewall. I hope this helps.
    Eric
    • Guy M.
      • November 1, 1993
      • 499
      Thanks Eric, it sure helps, very nice car, well done!
