1963 brake master cylinder date code - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1916
    I have a 1963 manual brake master cylinder with the proper markings. It has a date code of L302. Since I know that there are 63 master cylinders with M representing the month, I am assuming that L302 is November 30, 1962. I am also assuming that the letter I was not used to represent the month of September is this situation. Does that sound correct?
    • 6940
    Re: 1963 brake master cylinder date code
    Ed, With letters as date codes this is how it works - If you have a letter (M) the I was not used. and If you had a letter (L) the I was used. This was posted before by a regular here. I believe that the M was not used on Master Cylinders.
    • Edward M.
      • November 1, 1985
      • 1916
      A 63 owner posted on CF that he has an original February 63 build car with a master cylinder dated M283 (December 28, 63). Do we know for sure what the date code possibilities are for 63 master cylinders. I was thinking that the letter I would not be used to represent the month because it would be confused with the digit 1 in the date code. Inquiring minds...
        • 6940
        Ed, I could be wrong on the letter M, as I am not 100% sure .But the wording above is correct for letter dates.
        • Rich Y.
          Infrequent User
          • April 1, 2012
          • 24
          Here is a photo of my original '63 master cylinder.
          • Tom R.
            • December 20, 2010
            • 177
            The M283 master cylinder would have been correct for a 1964 model not a 1963. All December-built parts would have been made in 1962 for a 1963 car.
            Tom
            • Edward M.
              • November 1, 1985
              • 1916
              Tom
              Oops, sorry, typo. That should have been M282
              • Gary F.
                • August 29, 2010
                • 248
                The date code on mine says A-5-3, but my car wasn't built until March 18th.
