Re: Oil pump questions
Dennis bought the better pump, the Melling Select, which has a heavier casting in the critical neck area. The present day M55 and the Sealed Power 224-4146 (standard volume-high or standard pressure) both use cheapened castings which were changed about 8 years ago. The original GM pump used the heavier casting, like the Melling Select, and which were used by Sealed Power and Melling's standard design up until about 8 years ago. The Melling Select is on the right; the M55 is on the left:
Here is a link to the Melling relief springs, the first FOUR of which are compatible with the Sealed Power standard pump, the M55 and the Melling Select. Click on "click here" to view:
