Ool filter leaking - NCRS Discussion Boards
Ool filter leaking
  • Ronald F.
    • September 29, 2012
    • 135
    Ool filter leaking
    Just changed my oil and filter ony 67 L71 and when i started engine, oil poured out from filter. Redrained and refilled but same result even Though I tightened filter housing as hard as I could. Please help!
  • Ronald F.
    • 135
    Re: Ool filter leaking
    This is my first oil chage and I did put new gasket in.
    • Mike F.
      • April 25, 2011
      • 668
      Check to see if the o-ring/gasket from the first oil filter is stuck to the engine. Two o-rings leak like sieves (so I've heard).
      • John D.
        • June 30, 1991
        • 874
        ron
        Take it down and see if the old gasket is still there as well...been there done that.
        • Ronald F.
          • 135
          It wasn't leaking before I removed it. The old gasket was there and I removed it. I placed the new gasket on top of the filter housing and pushed it up against the engine as hard as I could and tightened the bolt. Where did I go wrong? A 20 minute job is now an all day job and still not done.
          • Stuart F.
            • August 31, 1996
            • 4676
            This is going to sound stupid, but are you sure the PRV is in place? As you know, it provides the groove for the O-Ring to seat. Sorry, but couldn't think of any other reason.
            Stu Fox
            • Larry M.
              • January 1, 1992
              • 2688
              That is not true. Many cars (mine included) had two gaskets at one time and did not leak. However, there are also many stories from those that had problems. The best bet is to install one NEW gasket at each oil change and remove the old gasket.
              Larry
              • Larry M.
                • January 1, 1992
                • 2688
                Make sure that the gasket is the correct square cut rubber gasket. A national vendor was supplying an incorrect round o-ring gasket with their oil filters. This is incorrect. Next remove any old gasket(s) and install the new one into the oil filter boss in the engine........not placed atop the filter can. Make certain the oil gasket sealing surface in the block is clean and not scored. Then install the new gasket with a bit of grease to keep it in place while you bolt up the oil can.
                You may have either used the wrong gasket or pinched/rolled the gasket by not seating it correctly in the block cavity.
                Larry
                • Ronald F.
                  • 135
                  Removed oil and filter and (now damaged) gasket and then this time I seated the (new) gasket into the engine groove first, THEN placed the filter housing in place and tightened it. This worked. Halleluiah!! THANKS, LARRY!!
                  • Mike F.
                    • April 25, 2011
                    • 668
                    Well, I've had the two gasket problem twice in 30 years, both times left several quarts of oil on the ground in about 10 seconds.
                    • Steven B.
                      • June 30, 1982
                      • 3976
                      When installing new filter and g asket put light coat of oil on mating surfaces of gasket, or bit of grease as suggested.Do not overtighten filter. Hand tighten will work.
                      • Timothy B.
                        • April 30, 1983
                        • 5177
                        Stu's got a good point, double check that the pressure relief valve is in place and centered.
                        Many times if the old gasket is difficult to remove try loosening the valve assembly then change the square gasket and snug the valve back in place. Don't break the 1/4" bolts, just snug.
                        • Bob H.
                          • July 31, 2000
                          • 789
                          A dental pic is great for removing the old gasket. I have always used a little grease to hold the new one in place.
                          • Kenneth B.
                            • August 31, 1984
                            • 2084
                            STEVE we are talking steel canister with a cartridge & long bolt with a washer that needs to be tightened with a wrench. Don't think he meant a spin on one.
                            • Gary N.
                              • August 31, 1986
                              • 118
                              I have a small drip at the bolt that goes into the canister. Can the washers be replaced? Where do you get a rebuild kit and is it easy to install?
                              Gary Nyland
                              1966 Black Corvette Air Coupe
                              2014 Black Z-51, 3LT Coupe
                              1955 Black Chevy Belair Gasser
                              1955 Nomad
