Driver side window will not go down. Passenger window operates with key on. How can I test to see if it is the motor, switch or wires in the drivers window that are bad? Door panel is removed and motor is unplugged. I have a digital voltmeter which is somewhat of a mystery to me. Should be simple but I am an electrical idiot. There is a dark blue wire to the motor that powers it up and a brown wire for down.
Power window problem
Re: Power window problem
Switches can be checked with Joe's method. Bad wire is usually in the tube that connects the door to the body. The wires get flexed every time you open/close the door. They won't last forever before they break.Terry- Top
Greg, Set the meter on VOLTS. Depending on the brand the selection point may say V, or it may offer you a range setting like 14v or 24v or 600v. If the latter select 14v. Put the black meter lead on a good bare metal point in the door -- one of the rivets for the window motor will work. Put the red lead on the connector with either of the wires and move the window switch first one direction then the other. If no reading on the meter, try the other wire and do the same thing. If you get readings at both wires motor is bad. If reading on one wire and not the other, either the switch or wire is bad.
Switches can be checked with Joe's method. Bad wire is usually in the tube that connects the door to the body. The wires get flexed every time you open/close the door. They won't last forever before they break.Summer over up there yet Terry? Talked to a retired AEP first line supervisor a couple of days ago here in TX and said he thought he met you a few years ago. 'can't remember his last name, though. First name Bill. About 5'10'', 165, red hair and beard, 60+. Steve
- Top
Joe!!???Summer over up there yet Terry? Talked to a retired AEP first line supervisor a couple of days ago here in TX and said he thought he met you a few years ago. 'can't remember his last name, though. First name Bill. About 5'10'', 165, red hair and beard, 60+. Steve
I just can't remember anyone's name -- even with references in hand (so to speak). Sounds like you are having the same problem.
If the guy from AEP was at one of the many NCRS events in Texas, it is possible -- but faces are only slightly better than names with me. It is socially embarrassing at times, but I have learned to live with it. I have been that way all my life.reg out -- or was it Joe, or Bob. WhateverTerry- Top
Terry, I cannot remember names either. Worst was after Nancy and I had been married 3 years, dated 3 years before that. I began to introduce her and forgot her name and couldn't remember it for a few minutes. I think all people should be required to wear name tags at all times (yes, even then). It would be a lot less embarrassing. Sounds like you having a good time. Steve
- Top
Thanks Terry. Up wire showed 11.6 volts with switch pushed to up. Down wire showed 0 with switch moved to down. Bad switch! Took a jumper wire from battery pos to down side of motor and window went down. Motor OK! Now let me ask, is there a way to rebuild switches or just buy new. Second question, motor is very slow and tired acting. Can motors be rebuilt or buy new if the goal is normal operation?- Top
Steve (Joe) how's this for fun?
[IMAGE]
http://s1277.photobucket.com/user/gismack/library/[IMAGE]
The picture is too big in my phone.
I don't know how to post a Photbucket link on here, but click on it.Terry- Top
Greg, its been a few years since I have done this with power window switches. If you flip the switch over the back side of the switch will have some release points to remove the switch, the chrome piece will stay together and you'll have the small copper flippers the activate the motor directions, a piece of sandpaper will clean the contact areas on the switch. Its a simple task once the switch is in hand.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Years ago on an old Caprice I had I rebuilt a failed switch, but I think new switches are available reasonably today. Those switches used to be generic across all GM car lines, and I am sure that is true of your 1972. Check availability from the aftermarket before you go trough all the trouble. I know nothing about the aftermarket situation.
[IMAGE]
I don't know how to post a Photbucket link on here, but click on it.- Top
Greg, its been a few years since I have done this with power window switches. If you flip the switch over the back side of the switch will have some release points to remove the switch, the chrome piece will stay together and you'll have the small copper flippers the activate the motor directions, a piece of sandpaper will clean the contact areas on the switch. Its a simple task once the switch is in hand.Terry- Top
Hmmm, I experienced after winter that my left pw goes up/down a lot SLOWER than before. I already checked the switch okay, but haven't touched anything else, yet. What might cause the speed of the motor to decrease? Bad motor, "gummed" grease, maybe?
I would assume a fault in the cables would make the motor not move at all, right?- Top
Terry- Top
