54 weatherstrip installation - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    Im not far from doing this and im looking for some advice for the doors, trunk and top lid. How have you folks done this without making a mess of things. Use the yellow glue? Tape it in place first? Doors have been adjusted to fit correctly without weatherstrip. This car will never really need it but I want it because its supposed to be there. Thanks for the advice.
  • Chris S.
    • January 1, 2000
    • 1064
    Re: 54 weatherstrip installation
    First - IF you are going for judging you will need the Diamond weatherstrip - there are two guys making the correct weatherstrip
    Let me know if you need their names
    Second - get the right glue - I use Weldwood brush on contact cement - IMO it looks just like the brownish glue used by the OE - I buy mine at ACE
    Third - get acid brushes - dont use the brush in the cap - I buy mine at ACE
    Fourth - start at one end - I brush on about 6 to 10 inches at a time - be sloppy - it was from the factory - set in place - hold - then tape with blue tape
    It will take you some time
    It is a PIA and is tedious but will look good when done
    WHen you are done - close the panel to help set the weatherstrip - it will be tight !!!!
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Guy M.
      • November 1, 1993
      • 499
      Thanks Chriss, it great to talk to someone who has actually done it. I bought the weatherstrip from CC. I hope I didnt screw up by doing so and the strips arent too large in comparison. I dont think Ill ever judge this car, doent have the original motor, came out of a 54 Belair. F54Z. I like hydraulics anyway.
      • Chris S.
        • January 1, 2000
        • 1064
        for me....the CC stuff and the 3M stuff - "yellow snot" is too yellow......
        The Weldwood is the closest I have seen.
        It takes alot of patience to put the wstrip on .......
