I have a 79 L82, 4-spd, A/C, car that I ordered new back in 1978. It is #421639, was built on 2/2/79, and delivered on 2/28/79. It has 23K original miles. I have all paperwork, records, manuals, etc.
On the return trip to CT from Corvettes at Carlisle last year, it spent the last leg of 140 miles on the back of a flatbed. The coil had failed. But, that was a good wake up call, as all of the original parts I've been running will only last so long. I replaced the coil with a big box store version to get the car up and running last fall. This year, I freshened up the ignition system. I replaced the cap, rotor, retainer, spark plugs, ignition wires (that was fun), coil, & ignition module. Except for the coil and module, for all parts I used NOS, GM service replacement, and/or as close to factory original as I could get. I used pertronix for the coil and module.
The next freshening up project I was planning on was to replace all 4 fan belts. I was planning on picking up all 4 at Carlisle this week. But, I'm running into a P/N discrepancy between the all original belts now on my car, the AIM P/N, the 3rd Ed NCRS TIM P/N, and Quanta part numbers.
Here's what I'm trying to resolve: (all belts are 4Q-78)
P/S Belt-
Original - GM 9433622 AY .380 X 36.0 DAYCO 5.5864 4:P:15
AIM - 9433622
TIM - 9433622
Quanta - 9633622
So good, so far.
Alternator -
Original - GM 9433654 CG .380 X 52.0 DAYCO 5-7244 4:P:18
AIM - 9433653
TIM - 9433653
Quanta - 9433653
Looks like car was assembled with the wrong (w/o A/C belt)?
A/C -
Original - GM 9433916 PE .500 X 55.5 DAYCO 42-1081 4:N:12
AIM - 9433915
TIM - 9433915
Quanta - 9433916
Don't know who is right here?
AIR pump -
Original - GM9433616 AS .380 X 33.0 DAYCO 5-7271 4:P:13
AIM - 9433616
TIM - 9433615
Quanta - 9433616
It looks like a yellow page revision 1 to the TIM made a previously correct number now out of step with all other "correct" references.
So, that's where I'm at.
Can someone with knowledge and/or experience in this specific area on a 79 comment on what belt P/Ns I should use to:
1) be factory correct; and
2) be fully functional in a car that is used sparingly.
It's clear that different belts will work across these applications. I'm looking for the best way to go.
Thanks !
P/S Belt-
AIM - 9433622
TIM - 9433622
Quanta - 9633622
So good, so far.
Alternator -
AIM - 9433653
TIM - 9433653
Quanta - 9433653
A/C -
AIM - 9433915
TIM - 9433915
Quanta - 9433916
AIR pump -
AIM - 9433616
TIM - 9433615
Quanta - 9433616
Thanks !
