Believe my subject has been discussed here before but can not find under "search". My questions applies to
all Chevy engines. Here goes: Have a 77 LS9 (350 S/B) Chevy P/U Shortbed. Ever since new after a ride on a hot
summer day I have noticed once parked in the garage overnight the top radiator hose "collapses" which I presume
is suction in the hose. When I open the radiator cap it turns back to normal. This truck does have the two seal cap
and the racovery tank from the factory. IIRC one of the fixes is to drill a small hole on the flat portion of the thermostat.
Here is my questions: 1) What causes this condition; anybody else have this problem?
2)What a some simple fixes for this problem? Does the small drilled hole in the "stat" do the trick?
Thanks in advance; Larry
